Gooding__R's avatar
Gooding__R
Triton V-10
I have a 2009 Coachmen Concord 27TS Class C. This unit has a Ford Diesel. The power and performance of this unit is great. I am looking at new Class A with the Triton V-10 and was hoping someone has some knowledge on the performance of the Class A up to 36ft. with this engine. I hate to lose the diesel power but I need more room.
  • Gooding. R wrote:
    Not sure of the weight but it has 325 HP. Guessing the weight around 7,000lb.
    The pickups and vans the came with the V10 weighed that much.
    just what kind of a MH are getting?
  • Not sure of the weight but it has 325 HP. Guessing the weight around 7,000lb.
  • Gjac's avatar
    Gjac
    Explorer III
    What was the HP rating of your diesel engine and how much did the MH weigh? What is the HP and weight of the new one? If the HP to weight ratio is similar you may not see much difference in performance.
  • Should do the job but just remember it is a small block and want to rev. You will pull hills at 4-5000 rpm but it will do that all day.
  • Just make sure its the post 2006 V10 with the 362 HP & 5 speed trann, 6-7 MPG. I've had an older V10 with the 305 HP & 4 speed tranny. AWFUL! The V10 with 305 HP & newer 5 speed Tranny in a small Class'C' is great, 10 mpg.
  • Colo Native wrote:
    Triton V10 is almost bullet proof but there is a difference with the gasser the RPM's run higher, the mileage is less 7-8 and if you go up mountains it will be slower. I went from a Class A gasser to a Diesel truck big difference IMO.
    We had a Triton V10, 6.8L F250 towing an 11k TT and it performed exactly like this along with the 7mpg when towing! Interesting.
  • Triton V10 is almost bullet proof but there is a difference with the gasser the RPM's run higher, the mileage is less 7-8 and if you go up mountains it will be slower. I went from a Class A gasser to a Diesel truck big difference IMO.
  • One of, if not THE best Ford engine, has been around for a long time, with good reason. Very capable, but very thirsty. But mileage is all relative in our pursuits, isn't it? Good luck with your decision.
  • It will perform acceptably, but you will not have the same HP or torque, especially in the lower rpm range. In other words, it will be slower to react to throttle changes than the diesel. Fuel mileage will also be lower.
