wolfe10
Oct 29, 2013Explorer
Since you can generate full boost on flat ground (my translation is for a short time) I would rule out a low boost turbo or leak in tubing or CAC-- at least for right now. Leaks don't magically fix themselves.
Since this low boost does occur under what I suspect is continued high throttle position, the first place I would look is the fuel filters. Restricted fuel flow will first show up under extended high demand situations. Start there.
38,763 PostsLatest Activity: Dec 25, 2025
