wolfe10
Oct 31, 2013Explorer
Dick,
Your chassis maker chooses the number and location of the filters.
You could have two, or just one. VERY CRITICAL DIFFERENCE!
If two, the first is a course filter element (10-30 micron) and the second a fine filter element (2-5 micron).
So, though the filter elements all fit the same filter base (i.e. you can get a 2 or a 30 micron element to fit the same filter base) using the wrong one can lead to problems. Worse case is if you have a single filter and fit the primary filter for a two filter system. Instead of filtering to 2 microns, you are filtering only to 30 microns-- that is like throwing rocks at the injectors.
So, check with your chassis manufacturer with your VIN.
38,764 PostsLatest Activity: Dec 23, 2025
