- timmacExplorer
sch911 wrote:
timmac wrote:
sch911 wrote:
So your most likely way over your GCWR towing a Stacker trailer behind an F53 based MH and you want more power? You need a decent DP....
It tows the stacker just fine but I am always looking for more power, nothing wrong with that.
"Tows it just fine" What about being dangerously overloaded? Where does that enter into your thought process?
Not So, if you knew my setup and what has been done to the motorhome hitch and frame and how I don't carry lots of stuff in the RV you would understand I am very safe, My total GVWR plus trailer weight is 25,500 lbs and I am at most 26,000 lbs plus 4 brakes on my trailer.
Safe over weight Yes, dangerously NO... - nevadanickExplorerWhy do you think its dangerously overloaded ?
- sch911Explorer
"Tows it just fine" What about being dangerously overloaded? Where does that enter into your thought process? - 4x4vanExplorer IIIYour wife is right! :D
- BigMacExplorerReally!??
timmac wrote:
its a 2007 3 valve v-10 with the Banks system but just trying to see what I can do to increase the HP/Torque even more.
Since you have started with Banks I would give them a call first.
http://shop.bankspower.com/c-25-products-forced-induction.html
The only question remaining is do you get the single :) or dual turbo :B- timmacExplorer
Matt_Colie wrote:
Tim,
As a guy that worked on several SI turbo programs, I can tell you that this is just not a great idea. The vehicles that have a turbocharger on a gas (SI - Spark Ignition) engines, did not just get a turbo and related plumbing bolted on. They are the result many manhours of dyno testing and calibration and most have some component modifications (like pistons) to survive the new cylinder pressures and heat.
If you want it to be reliable, leave it alone.
Matt
Yea after doing more research I have found a turbo can be a issue if not done right, I do have the 5 star tuning with the banks and it runs strong and pulls my trailer good but I am always looking for more power, that's just what I like to do, can never have enough power. - timmacExplorer
It tows the stacker just fine but I am always looking for more power, nothing wrong with that. - joloooteExplorerLOL
- carringbExplorerA supercharger would be easier to tune. They are available off-she-shelf for the V10, and are about a 5 hour install (maybe a couple more for a moho). You will need a custom tune that replaces the normal fuel-cut with an ignition cut (or only allow fuel cut with an injection cut). Even a modest 5 psi boost would add lots more power while still using pump gas.
