- thestarfinderExplorerYou are right Bill.....Just a piece of molding in front and they had 2 angle L brackets with 2 screws on each side (they drilled a small hole in the front of the washer)and screwed the bracket to it and the wood floor.....Going to pick up the new washer and will keep you guys posted on the progress...thanks again for all the help(comments) Tom
PS water lines have no shut off so will NOT disconnect till ready for other washer to go in..... - Bill_SatelliteExplorer III have not seen one bolted to the floor. They are generally very hard to maneuver in and out but there should only be moldings in and around the washer that holds it in place.
- thestarfinderExplorerOK guys.... I got a new washer at a great price on Ebay.......The old washer seems like it is attached to the wood floor of the cabinet....This is a Monaco Windsor 2001.....Is it bolted to the floor of this washer cabinet and is there anyway to get that washer out with out to much trouble?????
- ValkyriebushExplorer IIIf its not draining before spinning might be something caught in the impeller pump. Easy fix. This was my problem.
- Sez_Hoo_ExplorerMost of the parts for that model w/d are no longer available. Splendide wants you to buy the new model so they discontinued almost all the parts. That forces you to buy a new unit. There are other brand names companies that are making the combo w/d, you are not restricted to just Splendide
- thestarfinderExplorerThanks everyone...I will call ASAP...Thanks again,Tom
- Bill_SatelliteExplorer IIThey are great if you give them a call. Very helpful. I had a similar issue and it turned out to be a loose wire on the timer inside the housing. If you call you are going to need to have the washer out so you can check things out with them so you might as well pull it out and take a look yourself. The top comes off easily and you will be able to see the connections and controller from there.
- cbeierlExplorerHere's the number for Westland Sales (Splendide sales/support): 1-800-356-0766
- ValkyriebushExplorer IICall them, a tech will talk you through the repair. There great. Sorry don't have their #.
- NHIrishExplorerThis link is for the tech manual for splendide technicians. It is very helpful and may provide the answers you are looking for.
www.splendide.com/service/TRAINMANM_Complete.pdf
38,774 PostsLatest Activity: Mar 01, 2019
