txtode's avatar
txtode
Water pump--No power
Out of the blue my water pump lost power or ground. The salesman switch is by-passed. The on-off switches do not light up. Fuse in panel in bedroom is good. Fuse in line to pump is good. Is there another fuse? Getting power thru fuse in bedroom but no farther. Very confused.
Don
__________________
1999 Monaco Dynasty 40'PBS
  • Does your rig have the small comparment under the driver on the outside? If so the controller could be there.
  • txtode wrote:
    Thanks, will start searching today.
    Don
    No success in hunt for pump controller.
    Not in compartment with water pump. Not in rear 12v compartment. Not in front left 12v compartment. More tips on where to look needed.
    Thanks Don
    __________________
    1999 Dynasty 40'PBS
  • Replacing the monoplex controller is easy - finding it maybe tough.
    Don
    Ours is located on a side wall inside the compartment with the water pump.
  • Could be the pump controller if you have more than one ON/OFF switch for the pump.
