mark734's avatar
mark734
water pump fuse
i am trying to locate fuse for water pump on 2002 fleetwood southwind workhorse chassis thanks jw thompson
  • If your pumps not working then defective monoplex controler maybe the culprit. In my rig I ended up hooking up 12 volts directly to pump to determine it was working fine and replaced the controller.
  • There could be two. One should be in the DC power distribution panel. It is normally located behind small metal plate adjacent to the 120 volt circuit breakers.
    It could be in the battery control center.
    Another fuse sometimes is located next to the water pump itself.
