Jackie_TreehornExplorerNov 13, 2013Water Valve Leak Check and RepairI called Winnebago to ask about replacing a leaking valve and they suggested replacing the whole assembly that includes both a 1.5 inch gray water release valve and a 3 inch black water release valve....Show More
enblethenNomadNov 13, 2013You may have a cable actuated waste valve like these from Valterra. It is possible that the cable has pulled loose.Valves
Related ContentWater Leak, Repair Update Feb 12thAnderson kantleak water valveWhat is the object (air valve?) mounted above hot water tankMajor Repairscheck valves
