et2ExplorerJul 26, 2015Wheel hub oilSo how often do you guys & gals change your wheel hub oil oil? Frieghtliner says every two years. Cummins Bridgeway repair facility said, unless they're leaking don't worry about it. Not the answer I ...Show More
dons2346ExplorerJul 27, 2015While you are at it, make sure you get your relative bearings greased too
Related ContentWheel Hub oil!!Oil Hubs ( front)oil filled hubs/front wheelsOil filled front hubsOil bath hub's
