ricelake922
Jun 29, 2016Explorer
Where is reservoir to add fluid for the hydraulic jacks
Hello
I have a 1996 Monaco Dynasty that has RVA hydraulic jacks model JIMI levelling system and before I attempt to use the i would like to make sure that there is enough fluid to do so. Does anyone know where the reservoir is located? Is the 12 volt battery that runs the motor pump the same batteries that I use for the RV or do the jacks have their own separate battery? Also....can you please tell me where the pump is located? Thank you in advance.
