I have a 94 Toyota motorhome and have been playing with using a window AC. Not a duk tape install in a window, something different. I have an LG 8000btu AC with remote. My first attempt was to Mo...
Seems like I've seen window ACs installed in a few new small trailers using fridge vents for one side of the airflow. As I recall it is when the window AC is built into a cabinet so the back of the AC unit is flush (or nearly flush) with the side of the trailer. The fridge vent vents the portion of the airflow inside the cabinet.
Whats your goal with this? To use an AC you already have? If it is power savings there are power saver roof air models which may work for you.
