BillMFl
Apr 26, 2013Explorer
Arizona Kid wrote:
I don't think a Honda 1000 will run your AC. On those type of units the start up power needed is usually double the BTU's. So an 800 BTU AC will require 1600 watts of start power. I would also suggest the Honda 2000.
stan909 wrote:
Re shock absorbers. I think Bilstiens or Konis for RV use but seriously I think some put rubber around the opening or make a shelf with rubber for the AC to sit on. Low watt ACs are only around a hundred bucks so maybe it doesn't matter to you.like you. I bought my lil B to use without having to take the Bounder out and feel much more freedom. I am also trying to weane the wife away from the bigger rig for when we ritire and travel more. Thanks for your posts.
sizzy wrote:
What kind of inverter do you have? I don't really understand them but would like to be able to use the microwave.
