Gjac,
I just found out the other day that my wipers/washer will work with the key off. Now, does this mean EVERY MOTORHOME out there works the same. NO! There are so many folks that think all motorhomes are made the same and act the same. So, a test for you. See if they'll work or, turn on I should say, without turning the key on. If so, well, then maybe they're supposed to work that way and like I did, you just found out about it. But if they don't turn on when the key is off, then, try them again with the ingition on, then turn the key off and see if they continue to work.
If they do, somethings amiss here. Not sure just where to have you start looking. Different kind of problem here. Would be interested in the answer.
Scott
