Effy's avatar
Effy
Explorer II
Apr 23, 2014
wiring TV to existing coach speakers
So my question is a technical one. The dash radio in my MH has speakers built in the cabinets in the bedroom. I would like to use those speakers for my bedroom TV. The TV has RCA outs, which I would assume I can get RCA leads and splice to speaker wire to connect. I have a way to route the wire, but can I add the TV to those speakers and also keep the connections to the stereo? I wouldn’t use both simultaneously and logically I can’t see why you can’t supply a speaker from 2 sources. But it won’t back-feed the stereo will it? I don’t want to run an FM transmitter all the way to the front. Frankly I don’t want to run it through the stereo at all. I am simply trying to use the audio outs and wire to the existing coach speakers thereby controlled by the TV remote. If I wired through the stereo I would need to use it’s volume control and that makes no sense as it’s all the way in the front.
