Bob & Ann wrote:
You have great input on what could be causing the problems. It is most important that you check to see that the recall was done. It should also be checked if it was completed as to when the recall was completed. When the recall was fist done a lot found that they still had the problem and it needed to be redone. They perfected the recall repair about six months into the process.
Again: The P series chassis was never a part of the recall. The W20 and W22 were.
P series has Bendix brakes.
W series has Bosch.
