We also have the 2 burner for our longer trips. We also like the fact that the wind doesn't affect the output.
Similarly we noticed that low and slow isn't possible with this unit unless you set a flat bottomed cast iron pot on a griddle placed over the burner. That works for at home but for camping we just campfire cook for the low and slow.
Accessories? Essentially your accessories should be based on what you like to eat. If you eat a lot of BBQ and burgers, get the BBQ box. If you cook massive quantities of food for guests, then get accessories that help with that. Analyze how you prepare your favorite camp dishes and go with the accessories that work with that method so you don't overbuy items that you rarely or never use.
NickT wrote:
We have had a 2 burner CampChef for 5 or 6 years now.
Wouldn't leave home with out it!
Haven't found a wind strong enough to affect heat output....actually my only compliant if any is I can't turn it down far enough at certain times.
We have a single BBQ box which works fine.
I put a quick connect with a longer hose to run it on the house tanks.
Good piece of kit.
