- drdarrinExplorer
stro1965 wrote:
I thought it was as simple as buying a hose. Wrong. My grill has a pressure regulator that apparently has to go away if I want to use the low pressure hook- up on my RV. Anyone have an easy way to do this?
This won't solve your problem exactly but it may help you solve it.
I ended up with a Roadtrip LXE grill that didn't have a regulator and quickly found out, they are a real bear to find in the USA. Found some in Canada and a couple in the UK. With shipping the cost would have been over $60. So I too went looking for an alternative and I found it yesterday.
My Roadtrip grill is now connected to a standard regulated hose that goes to a bulk tank. The regulated hose has a standard 3/8" flare female connector. I found that a Watts 3/8 in FL x 3/8 in FIP coupling (LFA-176) has the correct thread size to screw onto the pipe that the regulator normally attaches to. These are available at Lowe's or Home Depot for between $2.50 and $3.25 each. Unfortunately, the hole diameter of that coupling is too small to allow the pipe to pass thru it. I expanded the existing hole with a 3/16" drill bit. That gave me the clearance I need to screw it onto the existing pipe but it looked like it might also interfere with the flow of gas to the grill, so I counterbored the coupling with a 3/8" drill bit.
A little yellow pipe tape on the threads (requires disassembly of the grill), screw on the coupling and it's good to go. Grill fires up nice and no leaks. - stro1965ExplorerI've cooked on the grill twice now...love it!
- Ron3rdExplorer IIINice work!
- stro1965ExplorerFor those interested, I finally finished. I went to a lot of places looking for a fitting to go on the gas tube where the regulator had been. Guess where I found it? On my workbench in the garage! It was in a box of spare air compressor parts! So anyway, here it is, works great on my initial test.
- stro1965ExplorerI have been to 2 hardware stores, 2 plumbing supply stores, a hose and fitting store and a propane gas dealer. No luck. I might end up with hose clamps yet!
stro1965 wrote:
I went ahead and took it all apart and have removed the regulator. I want to see if I can find brass fittings before I resort to hose clamps though. Not sure I'd feel good about that.
Thanks for the help guys.
Fittings are great if you can find them. The hose clamps would be no problem either as there's not a lot of pressure coming off the line as it's after the regulator on your tanks. Maybe 2 or 3 psi? - stro1965ExplorerI went ahead and took it all apart and have removed the regulator. I want to see if I can find brass fittings before I resort to hose clamps though. Not sure I'd feel good about that.
Thanks for the help guys. - Gene_GinnyExplorer
stro1965 wrote:
OOPS!, sorry, I missed that line when I posted the picture of what I did for mine.
... Mine is blue and the bottle screws on under the control valves, and the regulator is contained within a housing. .... - Gene_GinnyExplorerIf it is the old style Roadtrip the regulator will unscrew from the shaft. Hint, use a big wrench because that thing is on tight!
- stro1965Explorer
mpierce wrote:
If problem, then just put a quick connect on the high pressure side of the rigs regulator, and use the regulator on the grill.
I thought about that but it kinda defeats the purpose of the built in quick connect.
About Chefs on the Road
2,136 PostsLatest Activity: Jun 27, 2014
