wca01's avatar
wca01
NuWave as a Slow Cooker
The Nuwave induction cooktop can be set to very precise temperatures, and some have advanced the idea that it can replace a dedicated “Slow Cooker/Crock Pot” and save storage space.
I decided to give that a try, and since I don’t own a slow cooker, I did some research on slow cookers on the internet. I was surprised to learn that there is so much difference in the way that dedicated slow cookers maintain the temperature while cooking. It seems that different brands use different methods for their high and low settings. It seems that most do it by wattage and some do it by temperature. I don’t know the merits of either approach, but have read that many are not happy because the new slow cookers seem to cook at too high temperature. Well, this isn’t about dedicated slow cookers so I’ll leave those judgments to others who use dedicated slow cookers.
As I understand it, slow cooking is a concept that cooks the food at a simmer – not a boil. It intends to get the final temperature of the food to about 165 degrees F in a long time (4 to 8 hours). I have read that it takes slow cookers several hours to reach a temperature of the cooking medium to obtain the 165 degree F temperature of the food.
I decided to do some initial test of the performance of the NuWave in a cooking situation before I actually committed food to the issue. I decided that a temperature of 195 F would satisfy the slow cooking requirement. I put two quarts of water in a covered pot, set the temperature to 195 F and started the process. The first attempt at the test failed because I forgot that the default time on the NuWave is one hour. You can set it up to 99 hours. I recovered from that error and proceeded with the test with a cooking time of 3 hours.
The initial temperature of the water was 62 F, and the NuWave temp setting was 195 F. A Kill-A-Watt meter indicated that the initial wattage at this setting was 600 watts. It took about 45 minutes to get the two quarts of water to 195 F. As the temperature of the water approached 195 F, the NuWave started reducing the watt draw. When the temperature finally reached 195 F, the Nuwave would cycle between 0.6 watts and 56.0 watts. It then maintained the temperature of the water at 195 F +/- 2 degrees as long as I continued the test.
The test proved to me that the NuWave can be used for the slow cooking method, but at least two things should be considered.
1. The NuWave seems to reach the set temperature faster than conventional slow cookers. This could shorten cooking time.
2. The NuWave maintains the set temperature to very close tolerances. This could have an effect on the cooking time – shorter or longer, I don’t know.
Well, tomorrow, with the initial tests over, I’ll really try to cook “Slow Cooker Chicken Soup.” I’ll let you know how it worked.
Good Luck!
Wil
  • Thanks for your reply. This test is only intended to find out how the NuWave compares to a slow cooker before making any conclusions about if it is a reasonable alternative to a slow cooker. If it is thought that if it is, then some things can be said about the best way to use the NuWave as a slow cooker.
    Some things are already becoming evident. I'll comment on them when the test is over.
    You have already come to the conclusion that the NuWave is not suited to be a slow cooker because of the noise of the fan. Others may agree. One good thing about published tests is that they generally bring responses from people who have an opinion. That's a good thing!
    good Luck!
    Wil
  • It would be easy to overcome the time to reach 195, simply start it at a high temperature. You may be able to program it in. Give it a 10 minute start-up at 375 and then drop it to 195.
    I have avoided using it this way because I've never had a problem with bacteria in the crockpot. The biggest reason I don't use it for long cooking times is cooling fan noise.
  • Yes, please do post the results.
    I used my nice new induction-friendly small stockpot tonight to boil water for spaghetti on my Nuwave received for Christmas.
    It worked very well - really boiled the water very quickly, much faster than propane burner. I plugged it into an external outlet on the RV, placed on a little metal table. Avoided steaming up the inside of the RV.
    Really like the Nuwave cooktop so far. Good heat control. Will try it for stir fry dishes.
  • No I don't, but I don't throw stones at those who do.
    My mother made me fry a lot of chicken in a cast iron skillet.
    Cast iron takes too much care for me. But I don't have any issue with those who love cast iron. I hope you don't mind if I don't use cast iron.
    Good Luck!
    Wil
  • I don't have cast iron, but I think the only issue is if the cook ware works with the induction heat source. Cast iron and any cook ware with magnetic properties should work in a similar way.
    I carry a little magnet around to test most of the cook ware I see. It's just a go-no go situation.
    Good Luck!
    Wil
  • I would also be curious how this experiment goes with different types of cookware,(cast iron?). ;)
  • Very interesting test, look forward to your follow-up reports.
