BobsYourUncle's avatar
Nov 17, 2013
Oven "Broiler" Why is it a broiler with the same flame?
OK, here I am staying up later than I should and making a snack food I don't need....
Which brings me to the use of the oven broiler.
Now being an overly analytical person, I know from observation that it doesn't matter where you set that dial, all the heat comes from the same flame, on the bottom. There is no top flame or element as in our conventional electric oven.
So why is it that when you turn the knob all the way over that it suddenly becomes a broiler? I mean think about it - a broiler has the heat applied from the top down, not from the bottom up.
Being an analytical sort, I have pondered this point for years and finally decided to ask you guys!
Excuse me now, I have some "broiled" nacho chips and cheese to eat.
And they turned out well under the "broiler"......
  • outdoorlovers wrote:
    I've never used the RV oven. Just traded in our TT on a new FW. Salesperson asked the condition of the oven. I said, "I don't know. I've never turned it on." Have never been anxious to put anything in a propane oven.
    So why are you not to anxious to put anything in a propane oven?
    We had propane in our house until about 10 years, now we have natural gas, the food taste the same, am I missing something here?
    I like cornbread to much to give up the oven. Fresh out of the oven.
    And I also bake things for dinner too. When I make spaghetti, I need to have that with broiled toast.
    To each their own.
    Fred.
  • I've never used the RV oven. Just traded in our TT on a new FW. Salesperson asked the condition of the oven. I said, "I don't know. I've never turned it on." Have never been anxious to put anything in a propane oven.
  • Troll? Just kidding, and only because I just finished reading your other post of the night.
    The reason a electric range has a "Broil" setting is to shut off the lower heating element and turn on the upper heating element. There is no heat cut-off for the broiler setting to my knowledge, but it might have a safety cut-off around 400 - 500F.
    In a gas range - including my RV, the oven can be set to 400F and even higher up the dial is "Broil" - I am guessing that means the burner will not shut off until the oven is scorching hot, so if you happen to like your steak really well broiled, the flame will stay on for a really long time without cutting out once the oven is warm.
    The only thing I have ever broiled in my RV oven is sourdough toast, already buttered, it comes out great. However in the home range, I have cooked a steak once. Most of the time I prefer the BBQ.
    I don't think I would own a RV without a oven.
    Fred.
  • Yeah, I guess I guess there is room to slide a sheet pan in there. Not a lot of clearance to the flame!
    But like you say, watch it!
  • Well in our oven I slide the sheet pan under the bottom cover so my goodies are below the flame.........watch it closely
    I do my nachos in the microwave....ain't got time to wait for the broiler when it's snack time 40 secs and I'm scarfing :B
    'Broil' on the knob just allows the flame to stay on vs other temp settings where main flame will go out then relight as temp is satisfied then drops temp.
