J_herb's avatar
J_herb
Explorer II
Nov 15, 2013
ACER netbook to desk top monitor
I have a ACER netbook windows 7 with a 11" screen and I hooked it up to my 20" monitor with a HDMI cable and it works good, but my netbooks screen stays on too, is this normal? Thanks in advance. Jay
  • J herb wrote:
    Gdetrailer wrote:
    J herb wrote:
    1492,
    thank you for all the help, it worked great as you said it would.
    My XP will be no good after April 2014 so I have this ACER just sitting around and I thought why not use it as my main computer and get a tablet for when not at home.
    1492, thank you for all you do for us on the RV net. Jay
    XP WILL still be "usable" after April 2014, it WILL still FUNCTION.
    What will happen after April of 2014 is MS will no longer be issuing MINOR security patches and any "enhancements" or "hot fixes". If there is a MAJOR security "hole" they may decide to issue and update.
    XP will still be alive and going for many years since there are companies still using it and will be for a long, long time after MS drops support.
    Heck, I still have a PC laying around with 98SE on it and it still works and I would still use it for Internet stuff but you can't get newer browsers to run on it.
    I know that XP will still work but you loose your protection when you do banking, or other things on the internet. Their is enough problems on the net without updated security. I have this netbook with windows 7 sitting around not being used so I will use it and buy a tablet to use away from home.
    Most MS patches really do not affect things like banking or personal info. Basically the patches are to fix "security holes" IF some hacker managed to find that hole, then write code for it then inserted that code into your banks website.
    Plus when you connect to a bank site it is a secure hhtps connection which basically encrypts all data between the bank and your PC (no one can "eves drop").
    All said you will have an extremely small remote chance of having your baking info being stolen.
    Besides, no matter how much patching is done, as long as you are willing to go out on the wobbly web you are always "risking" your PC.
    In other words even with the newest OS with all the latest patches you are no better off than if you were running say W98SE as long as you are on the wobbly web..
    I have personally had a up to date well patched PC with all the latest AV definitions which is behind a very high security firewall crumble into a smoldering doorstop from a drive by malware attack on a pretty much safe website.
    You are only kidding yourself if you think security patches will prevent anything from happening...
  • Gdetrailer wrote:
    J herb wrote:
    1492,
  • J herb wrote:
    1492,
  • kaydeejay and RFW63050,
    thanks for the help, Jay
  • 1492,
  • kaydeejay wrote:
    You should be able to turn your screen off using "Fn" + "F6".
    I have an ACER 11.6" Netbook right in front of me, and this is the way to blank the notebook's screen when using an external monitor. Or if you want your ACER to blank automatically when you connect your HDMI, then go into Dispay>Screen Resolution and set "Multiple displays" to "Show desktop only on 2". Note that multiple displays option is only available in WIN 7 when you're connected to two monitors.
  • Or you can extend the screen, which allows you to have one screen for one process and the other screen for something else (ie... Browsing on one, reading email on the other).
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
