- Tom_M1ExplorerMake sure it's digital popcorn.
- Johno02ExplorerGet the popcorn. will that antenna work for HD digital signals, or is it analog only??
- BumpyroadExplorer
Horizon170 wrote:
I wonder how this compares to the Batwing?
https://www.antennasdirect.com/store/clearstream-4-ultra-long-range-outdoor-dtv-antenna.html
EDIT---How do I make this a HOT LINK?
gotta be better . has patented loop technology. ;)
bumpy - wa8yxmExplorer IIIHow to make a hot link.. Ok, this is the link you posted
Now, using SQUARE brackets (I will use Curley, same key shifted) you modify like this
{url}https://www.antennasdirect.com/store/clearstream-4-ultra-long-range-outdoor-dtv-antenna.html{/url}
so it comes out like this
Or you can use the ADVANCED POST FORM and click on the proper icon (Globe or chain link)
As for the antenna.. I do not believe it will out perform a batwing.. For one thing it is UHF only very poor performance on VHF and some stations are still in the VHF band, Mostly VHF HIGH, But even a few left in VHF Low.. - RoyBExplorer III have one of these for the house and have used it with the OFF-ROAD POPUP trailer I have. It works better then my BATWING but the directivity was a pain. Had to be zero'ed in on the signal.. The BATWING picked up the same signal and didn't have to move it around much.
google image
I was also afraid of the wind load in my case.
This cost was much less than what I read on your's... $69
My setup using the BATWINg antenna back in the woods is hard to beat for me...
Roy's image
Roy Ken - SCVJeffExplorer
Ed_Gee wrote:
And if this latest channel auction ever gets some traction there will again be a completely populated VHF one day.Dutch_12078 wrote:
That antenna is for receiving stations broadcasting on UHF channels only. It will not receive the several hundred stations broadcasting on VHF channels unless they're next door to you.
I wonder how many people this fact flys right over their heads?
Back to the antenna.. for UHF, a 4 Bay Bowtie is hard to beat for its size. The published gain on that loop, if true is pretty impressive - Ed_GeeExplorer II
I wonder how many people this fact flys right over their heads? - FizzExplorerI tried one of these and the Batwing was better.
- IAMICHABODExplorer II
Just follow the instructions inThis Clicky EZ to do - Bill_SatelliteExplorer IIThat's a good antenna as are nearly all the antennas of that basic design. However, it is not necessarily any better than a good Batwing with the Wingman attachment (or a Sensar IV). If you have an easy way to attach the antenna and put it up and down then do not hesitate in giving it a try but you can likely do as well by ensuring your Batwing it up-to-date and getting the proper voltage and signal. If you are WAY out there (60+ miles) from a tower there is a good chance that the antenna you show on a very tall pole will do better but so would a Batwing mounted on a very tall pole.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Aug 21, 2025
