bennefim's avatar
bennefim
Dish vip211k receiver
would like to verify with current rv user if you can connect hdmi to tv 1 and coax to tv 2, and watch same channel at same time. I have received conflicting information. Some say you can only watch one tv at a time (only one output hot at once). if you have this setup, please verify. Private messages welcome.
Doug
  • We no longer have DISH, but I used both HMDI and the Red-Yellow-White plugs to the same television. And they both worked. Never tried them at the same time. Turns out, when I had Dish using the HMDI, my surround sound in the camper did not work. Sound only came from the television. When I switched over to the R-Y-W input, my surround sound worked through the radio-equalizer system. We used the R-Y-W input on that television more. Also, with R-Y-W, my outside speakers worked to. On HMDI, none of the speakers in the camper carried the sound.
    So, to answer your question, both are active, and I imagine the coax connection is also active.
    We quite DISH-TV by the way. Got tired of them constantly raising prices. Found out over-the-air satisfies our television preference just fine and doesn't cost anything, and no more haggling every time we had a bill increase.
  • Our TT had the TV in the living room with HDMI and the bedroom with coax. Both worked at the same time but with the same program. Ours is a 211K. We put the coax from the 211 to the antenna connection and turned off the booster and got the dish to the bedroom and outside tv without running any new lines.
  • Definitely can. I have my living room TV connected to the vip211k via the HDMI cable for HD. The bedroom TV is connected to the vip211k via the coax. I can watch either TV or both TVs at the same time, but they will both show the same channel as the vip211k is a single tuner receiver. Been doing it for years.
    You do not need two receivers unless you want to watch different programs on each TV.
  • Short answer, yes. Note: you can only get SD on the TV with the coax feed. If HD is a must you might consider running component video cables to the second tv instead. Another solution would be to buy an HDMI splitter which would allow HDMI feed from the 211 to multiple tv's.
  • Each TV needs a receiver to work with satellite.
    Both our TV's, one with a 211K and the other a 211Z, use HDMI.
    PM's don't share info with the community.
  • I have a 211 and since my HDMI, RCA, and F connector is selected by the TV, not the 211 I think all outputs are hot at once as there is no selection on the receiver but am interested in seeing the answers. I don't know why you couldn't just split the output from the 211 and run it to as many TVs as desired. I have three TVs linked to my main dual receiver.
    bumpy
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
