Bob_Vaughn's avatar
Bob_Vaughn
Jensen intertainment center
My system went off while driving to the campground it is a AWM970...I found a 15 amp fuse but after changing that it still would not come on. There is 12 volt power in the slide out. So I am at a loss as to why it went off. The instruction manual does not have a trouble shooting section.
  • Next would be to get a test light or meter in there to see if you have 12v to the plug on the back of the radio.
  • schlep1967 wrote:
    If you can get to the wires behind the system, try moving them around and see if you get intermittent power. I had an issue where the radio moving up and down eventually broke the wires where the plug goes into the back of the radio.
    First thing I did there are a couple dozen wires back there I could not find any thing that had come loose......
  • If you can get to the wires behind the system, try moving them around and see if you get intermittent power. I had an issue where the radio moving up and down eventually broke the wires where the plug goes into the back of the radio.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
