Greyghost's avatar
Greyghost
Using Directv HDDVR versus HD
We currently have a Genie HDDVR in the S&B and an HD receiver in the MH. We're leaving for 6 months and my better half would like to record some shows.
Our dish is a Slimline with an SL3PIG-Z LNb (one horn, 4 outputs). One output to the front TV and one output to the rear TV.
The S&B has a device that is plugged into the coax network (I'm told this is a SWM?) and plugged into the wall outlet for power.
I can't get the Genie to work in the MH. With the SWM plugged in or not. What setup should I be using for the connection? If I need the SWM box, how should it be connected?
BTW - directv systems are down for support.
  • you want to record at home, or on the road ?
    you should be able to record at home, and play the DVR recordings in the camper
    even IF you can't connect the Genie to the dish
    i don't have any satellite equipment, so maybe my memory of previous postings is a little fuzzy
  • Thanks Al,
    The dish I am using is mounted on a tripod. The dish on the roof of the MH is a KVH in motion for Dish Network. I'll check the links you provided and see what happens. It could be that my wife does not get to record again this year.
  • I don't think The antenna you have in the MH is SWM, and the Genie requires a SWM. In addition to the SWM power inserter, you'll need a switch like this one to adapt your antenna to the SWM receiver. The switch also requires a different power inserter than the one from your S&B. There's a lot of info on wiring up a SWM8 switch here.
    al
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 27, 2026
