Tom_M1's avatar
Tom_M1
Winegard vs. Jack antenna (again)
This is my second attempt to do a Winegard vs. Jack antenna comparison.
Here's my test setup:
Antennas: Winegard Sensar III with Wingman attachment and King Controls Jack antenna head unit.
Tuner: SiliconDust HDHomeRun Tech3 connected to computer via network cable.
Cable: 30ft. of RG-6 quad shield with power injector inserted at tuner end.
I'm camped out in the boondocks of south Florida and thought it would be good spot to do a test. There are no structures around to cause multipath problems or block the signal. I'm far enough away from the transmit sites that overloading would not be a problem.
For the antenna connection, there is no added amplification. The only thing in the line is a power injector that sends 12 volts to the amplifier built into the antenna.
I started with the Winegard attached to the crank-up assembly on the roof of my coach. I aimed the antenna toward West Palm Beach which is 142° from where I'm camped. For measuring signal level I used the setup software for the SiliconDust HDHomeRun tuner. The software displays levels in DBs rather than percent. I peaked for maximum signal, and scanned through the channels. I did not reposition the antenna for stations coming from other locations.
I then installed the Jack antenna. I had to rotate the antenna 90° so that it pointed in the same direction as the Winegard.
Here are my findings:
As expected, the Winegard did better for the VHF channels, but the Jack was better on all the UHF channels.
SCVJeff did a thorough test using a spectrum analyzer and came up with different results. It's possible I have a defective Winegard or he had a defective Jack. Many people have reported having better reception with the Jack and others worse.
I have opted to stick with the Winegard because of it's better VHF performance.
I think more testing is needed.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 21, 2026
