- wildtoadExplorer III installed one in my last MH and it worked just fine. I had to enlarge the opening a bit, but no big deal. As mentioned above, the instructions were spot on, and very easy to hookup. Keep in mind that the new Sensar Pro does not have a cable out on the front panel like the old one, so if you are using it, then you will need to adjust the setup.
- 1492ModeratorMoved from Forum Technical Support
- lj2654ExplorerI just recently installed a sensar pro in my 2001 Beaver coach. I have been having issues with my OTA antenna for a couple of months. I decided to replace the antenna with a winegard sensar 4 antenna ansd install the sensar pro with it.
First issue I had was that I had a bad cable feed wire that had kinked where it enters the roof. I replaced the whole cable from the top fitting of the antenna into the coach.
The sensar pro was mostly switching out the old winegard receptacle that had the 12 volt opening and a button to push for turning the antenna amplifier on. This was easy to do and the directions were quite good. The only issue I had was tracing all my tv cable wires and marking them as to what they were hooked up to. Yours may be just swapping out the three cable wires and a positive and negative wire for the amplifier.
I went from receiving one channel to receiving 31 channels now. I love it. Wish I had done it sooner.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
