luvcycles2ExplorerNov 09, 2015bypass valveHi all. may be a dumb ? but can anyone tell me if in bypass mode should I get water from the hot and cold side of the faucet?Thanks Phil
14 RepliesReplies sorted by NewestShow Moreksg5000Explorer IINov 09, 2015Yep - you know its working because your "hot" water won't be hot.Artum_SnowbirdExplorerNov 09, 2015Yes you should... all you have done is disconnected the hot water tank from the flow. It must operate this way so that you can winterize with antifreeze in all your hot and cold water lines EXCEPT the hot water tank!korbeExplorerNov 09, 2015My manual valve configuration routes the cold water inlet to the hot water outlet at the tank. So in my case, the cold water will run through the hot water lines.filthy_beastExplorerNov 09, 2015Yes you will, but the water does not go into the heater, it just bypasses it.
Related ContentWater Heater bypass valve.Water Heater Bypass Valve - How To ReplaceHot water tank bypass valvesHot Water Heater Bypass ValvesRut Roh....Water heater bypass valve kaput?
