wing_zealot wrote:
It will work only marginally at best. The longer the hose you use to connect, the worse it will be. The more burners you use the worse it will be. You will get much more satisfactory results if you just use it directly off a propane tank instead of the quick connect. Ask me how I know all this.
...or remove the regulator like a lot of Weber Q owners do.  You can search the topic and if you have a removable regulator, it's fairly easy.  Most regulators I've seen are 1/8" pipe thread.  Let me know if you need more info.
