Vic_Bc
Nov 29, 2014Explorer
First time Winterizing. Couple questions
So I should have done this way sooner so I'm in a little bit of a pannick mode here as it's supposed to drop to -2 tonight and I'm a little worried.
I have drained my fresh, black and grey water tanks but ran into a problem when trying to remove the drain plug for the water heater. I have never used the water heater once since I bought it (4-5 months ago) it's always been in the off position but right the the plug is stuck in there pretty good and I won't be able to find the right tools until tomorrow to drain it. Just hoping I'll be OK for the night.
As for pumping through antifreeze before I actually go ahead and start the process I wanted to check with you guys about a couple things.
WATER HEATER:
From the videos I have seen you need to turn off the valves so water does not get into the heater. I have located the back of my heater and there are two valves. Do I switch both of these off?
As for the water pump, I found an old tube that looks like it was used in the past to do what I'm thinking. I'm not sure which hose exactly pumps the water but my instinct tells me it's the one I have circled in this picture. Am I on the right track?
WATER HEATER:
