  • path1 wrote:
    Is this correct link to them?
    https://www.posi-products.com/
    Yep
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I just finished a 1300 mile tow of my car. Which hasd a lube pump. about 500 miles into the tow the pump alarm went off. I was only a few miles from Parked so I fired up the car's engine to pump the fluid and finished the trip
    There have been a few issues with this pump. The original pump failed. so it was repalced. this one blows fuses. So I tried a circuit breaker, Promptly blew the controller.. I should have de-engineered further on the controller and found if I could just beef up what failed but alas. I did not.
    So I added a relay The power to the relay contacts is tapped into the power to the controller line with FOUR, count them FOUR "Stocth lock" type connectors ALL FOUR FAILED
    now spliced and soldered SOLID.
  • Either use non-insulated splices/terminals and a separate piece heat shrink or splices/terminals that have shrinkable insulation.
    Done correctly a crimped connection is just as good and some way netter than solder.
    If you are running new wire, use "marine", pre-tinned wire. This greatly reduces corrosion.
  • wa8yxm wrote:
    ... count them FOUR "Stocth lock" type connectors ALL FOUR FAILED ...
    I hate Scotch Lock taps ! I will not use them and if I find them i critical places I replace them !!
    They are the worst.
  • I use butt/bullet connectors and put heat shrink tubing around them. If I need to take them apart I slit the heat shrink and pull them apart.
  • I knew the brake wiring on my new utility trailer was undersized so I thought I would look a little closer before I run a 12 G blue wire from the 7 way harness back. Another problem is that they used a cheap 7 way cord that is 16 G.
    They did use heat shrink....
