Troutbug
Jun 15, 2016Explorer
Air in water line - how to access tank/hose?
Hi all, I recently purchased a 1993 Lance 300 and am getting acquainted with it. It seems that air is entering our water line somewhere as the faucets are very sputtery. The pump runs fine, I've checked the pump for tight seals, and I suspect it might be the line from the fresh tank to the pump that is allowing air in. But I cannot find a way to access the lower half of the hose where it connects to the tank; it seems to be behind permanent walls with no access panels. Am I out of luck for checking the tank-to-pump hose on a 1993 Lance 300? Any insights would be appreciated. Thanks much, Josh
