Muddydogs's avatar
Muddydogs
Anderson No Sway chain WD hitch? Pics added.
To start off I have read through some of the old Anderson hitch posts which are a couple years old and discussing the new hitch in general.
What I am wanting is feed back from guys that have ran the hitches for a couple years. I have about 2500 miles on my Anderson hitch and I am seeing a lot of ball wear as well as some of the red liner in the hitch head is squeezing out. For a hitch that is supposed to be greaseless and there isn't supposed to be a whole lot of movement between the top of the ball and hitch due to the ball turning as the truck turns I sure am seeing signs that the trailer moves around on the ball like one would with a conventional hitch.
Some of my concern is maybe something isn't set up right, the dealer did forget to put the washers between the adjustment nut and red rubber things when I first picked it up. I figured something was amiss when the nut started to suck into the rubber bushing and took it back in.
So what are you guys with the Anderson no sway hitch seeing?
  • I sprayed/coated my ball with "SLIP" a highly recommended dry lubricant and it worked well for the couple of years I used it. Only downside is its a black coating and not as pretty as a plain shiny aluminum ball. The antisway function provided by the chains was not impacted. SLIP is available in a spray can on Amazon.
  • The bushing is made to wear it sounds like you need a new bushing from not being set up right.there are YouTube videos on this.
