1ed's avatar
1ed
Explorer II
Aug 25, 2020
Assist Handle Modifications to Prevent Lock-in
Reading a story of a couple that were locked in the rv due to someone moving assist handle across the door. What if any mods have you done to prevent being locked in you rv? Thanks Ed
  • The assist handle on my Wolfcreek TC is made such that if it is across the door, the door can still be opened from the inside. As the door is opened to the outside, it will push the assist handle out of its detent. You can't be locked in.
    ryoung
  • Keep a little WD40 in the valley, door pops right open.
  • 1ed's avatar
    1ed
    Explorer II
    I checked my Trailer a 2020 Mini Lite from Rockwood and if you close the handle over the door and pull on the door with any force it will open. When I read this story I was really concerned and
    thought of all the terrible situations that could occur with that door not being able to open. Great topic and maybe it will help someone... Thanks Ed
  • Exactly. You don't want it flapping while you drive and you don't want it to fold up while you're using it.
  • CavemanCharlie wrote:
    dodge guy wrote:
    Get a hard piece of plastic and cut it to fit the opening. Then screw it into the cavity so it will just swing out.
    Or, just grind down the "bump" that the handle has to go up and over to move it. Then you will be able to push it open with the door.
    I never thought of this before. I'm glad you brought it up.
    As long as there is a little something left somthe handle doesn't flop back and forth!
  • I wouldn’t have any handle that could even temporarily block my exit.
  • Get a hard piece of plastic and cut it to fit the opening. Then screw it into the cavity so it will just swing out.
  • Here is one way that has been used by others on RV.Net
    LINK
    My handle has a landing like the one pictured after the mod,it came that way,no way that it will trap me.
    I have closed and flipped it over the door and with a good push it pops open.
  • Do you have a window next to your door (or even in your door)? If so, just open the window and release the handle.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
