chuckbear's avatar
chuckbear
Beware Camco Water Heater Tank Rinser
I bought one of these to clean my hot Water tank. Five seconds after I started, the long tube blew off inside the water heater where it now permanently resides. I don't know what this means for the future of the water heater but would advise others to use extreme caution in using this poorly designed and manufactured device. Chuck
  • If Atwood drain hole is only 1/2" opening...may be too small to use grabber and pull tube out
    Suburban has 3/4" drain hole and MIGHT be able to use grabber
    Personally I would remove element ...1" Opening
    Plastic....Suburban WH it could get stuck between combustion/exhaust 'U' tube which is STACKED on top of each other.
    Plastic up against combustion/exhaust 'U' Tube can melt
    Less chance with Atwood due to diagonal 'U' Tube...
    Water temps could reach 170*/180*F if T-STAT Fails which could make that cheap plastic very soft/pliable (heck 130*/140*F might also...don't know temp rating of that cheap plastic)
    Remove it...be done with it....why leave it to cause problems
  • just leave the plug out, turn on water and plastic piece should work its way to the hole...then grab with some needle nose pliers.
  • I would ignore it. it's a plastic tube it's not going to hurt anything.
  • chuckbear wrote:
    bukhrn wrote:
    Try one of these, you'll have to be extremely patient & lucky, but it beats leaving that thing in there.
    Thanks. I have ordered one of these. Hope it does the job. Chuck
    Good Luck, just remember, it's like fishing in the dark, and if it doesn't work, it's always handy around the house for other things.
  • Had one of those Camco Water Filler that you attach to your hose then stick down into gravity port to fill fresh water tank
    Second time I used it the Tube blew off.....been inside my fresh water tank since 2008
    Plastic tube inside your Water Heater????
    I can see several issues:
    Getting hung up on one of the Dip Tubes
    Banging around breaking one of the DIP Tubes
    Getting stuck in drain hole and blocking draining of tank
    If Suburban ....easy to remove the electric element and give you larger hole to retrieve it from
    Same if Atwood ...access not as easy due to element being installed from backside of tank
    Either way....I would remove it
    CAMCO......CHEAP, JUNK and I refuse to purcahse anything from CAMCO
    HINT:
    In further to flush water heater
    Turn water supply off
    Relive System Pressure...open faucet hotside
    Remove drain plug
    Turn Water Supply ON...FULL
    Stand back and let it BLAST out the drain hole
    *Cold inlet dip tube points downward and will stir up sediment on bottom of tank
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 09, 2026
