drillagent's avatar
drillagent
Blow Lines or AntiFreeze, or both?
I've read a lot of threads about winterization. Some say blow the lines, some say fill the lines with antifreeze. But I still have a few questions. I'm sure I'll get a number of opinions, but I figure it's like reading product reviews. If the majority goes one way, then that becomes a factor in the decision making process. The more info I get, the better informed decision I can make. Thanks.
If you blow the lines, will there be residual water that can burst a line?
What's the chance of bursting a line with an air compressor?
If you blow the lines, do you really need antifreeze in the lines?
How do you drain the washing machine connection without having water/antifreeze everywhere?
If I want to use the rig during the winter, can I just blow the lines after each use and not waste antifreeze?
