Walaby's avatar
Walaby
Explorer II
May 10, 2018
Blue Ox Sway Pro Setup question UPDATE
I have a B.O Sway Pro 1500, Prime Time Lacrosse 324RST TT and Ram 2500 CTD.
When hooked up, TT and TV are level. Hitch/Bars setup on 10th link. Tongue Weight is 1480 with two 30lb propane tanks, TT loaded to rock, along with ~15 gal of fresh water (~120 lbs).
When setup on 10th link, I am still 160lbs lighter on front axle than unhitched weight. Even when I use the tongue jack and raise the hitch to the point where back wheels are just about off the ground, it takes a fair amount of effort to hook up the bars. I can do it fine, but if wife ever had to do it, she couldn't.
Since I am close to bar max, Im thinking about upgrading to 2000 lb bars. The max I'd be is the 1480 tongue weight, and I don't always carry that much water, and of course, propane tanks empty over time.
Regardless of decision to upgrade bars, I'd like to get a little more weight back on front axle, but don't want to go past 10 links. Since trailer is level when hitched, Im thinking I should LOWER the hitch by one hole (~1.5 inch). Will doing that (a) increase the leverage and add weight to front and/or (b) allow me to hitch at maybe 9th link? Or would I see just the opposite effect?
Alternatively/additionally, if i upgrade to 2k bars, does that have any impact on how much weight is transferred to front (assuming same 10th link)? Im guessing not, since leverage is the same.
Tows real nice as is... I would just like to be able to hitch it up easier (so wife could do it if necessary).
I would THINK that dropping the hitch 1.5" would change the leverage and either give me same transfer at maybe the 9th link, or get more weight on the front on 10th link.
Thoughts???
Mike
Looking for advice before your next adventure? Look no further.25,164 PostsLatest Activity: Sep 18, 2025
