- robatthelakeExplorerThe Automatic Hubs work fine as long as You run the vehicle in D 2 WD before placing the transfer case in Nuetral and the Tranny in Park!
It's when You have it in 4 WD before shifting the transfer case to neutral that You create a problem .
Just drive the car around for a hundred feet or so in 2 WD before hooking it up! - Nutinelse2doExplorer
rv2go wrote:
I towed a '95 Geo Tracker, 4x4 auto with manual hubs for years and many thousands of miles. Transfer case in neutral, Trany in Park, Hubs unlocked, Steering wheel unlocked.
X2 Great little tow cars - Tow bar yes.
You need to check to see if there is a white sticker with a 4-6 digit number on brackets. It maybe hard to get an adapter without having one made.
1.125 square inserts are common for Roadmaster. Go to their website to see if that is what you have. Roadmasterinc.com - kcgazExplorerThanks for all of the great input. In looking at the tow setup, there are two square pieces that are welded to the frame with holes. I have a Stowmaster tow bar on my 94 Suzuki Sidekick, can that be adapted to work on the 92 Geo Tracker? As always thanks in advance for your assistance!
- Yes, it can be towed four down.
Make sure it has or you will need manual locking hubs. Some were not equipped with locking hubs.
Transfer case in neutral, transmission in park. Stop every 250 miles and run transmission in drive. - DougEExplorerBeen there. Done that. Key to off, but not lock. Manual hubs in freewheel. Transmission in park. Transfer case in neutral.
Every 200 miles or less: Start engine, put transmission in drive, and run for a minute. This is necessary to lube the transfer case occasionally. It does not splash lube unless being turned by the engine. Put transmission back in park, stop engine, and continue on.
While lubing the transfer case I leave the driver's door open so I don't forget to take the necessary action to continue towing.
I bought my Sidekick with 35k miles on it and sold it with 125k miles on it. No transfer case issues.
BTW the auto is a chevy trans. Chevy parts will fit and are much cheaper than Suzuki parts. Plugs, seals, etc. - The_TexanExplorerYes, but you have to have manual hubs installed. Towed a 96 for years.
- rv2goExplorer III towed a '95 Geo Tracker, 4x4 auto with manual hubs for years and many thousands of miles. Transfer case in neutral, Trany in Park, Hubs unlocked, Steering wheel unlocked.
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 21, 2026
