Colorado71's avatar
Colorado71
Carrying a dirt bike on the hitch of bumer pull TT?
I want to get a hitch installed on the rear of my TT so I can carry a dirt bike.
The bike is 220lb, probably closer to 240 wet. The travel trailer is a Nash 19B (has a heavy duty off road frame and is ~ 5,000lb ready to go). It also has had it's axle's flipped so it sits about 6" higher.
The truck is a plenty capable QCLB 3/4 Ton Ram with the 5.9 Cummins/6spd manual tranny.
But 300 odd pounds that far over the rear of the TT is going to lower the tongue weight a LOT! I'd imagine I'd need to lower the ball on the hitch to get the tongue weight back where it needs to be. But how much is the question.
Or are there other factors that make this a bad idea? What are your thoughts guys?
  • I am in the same situation. getting ready to buy my first setup and i want a toy hauler but I need something to tow the jetskis also. So i am thinking Id have to go 5th wheel for I see alot of them are designed to tow. I did find out some neat information about towing two trailers. Some states its legal some its not. So how does that work when going through other states?, I dont know. But in kansas its legal if your withing the weights. Also last vehicle must have brake assist on the axle.
  • I don't think I'd do it. Not that heavy a bike. Any chance to modify the hitch assembly of the trailer to carry the bike? Mind you getting it up on the trailer would be ugly.
