- mowermechExplorer IIJust my opinion, NOT a recommendation nor an "OK, go ahead and do it":
Yes, I think you CAN tow it. You won't set any acceleration or speed records, and you may not be able to use overdrive very often, and you will have to inspect your entire hitch assembly often for bends and/or cracks and or loose/stretched bolts, but it can be done.
Would I do it, if it were MY rig? Probably. SHOULD you (or anybody else) do it?
That isn't my decision to make.
Good luck. - rk911Explorer
Dr.Chenny wrote:
It is a ford.
then it's probably not a 454 but a SuperDuty F53 producing 305 hp and you likely have a Class III hitch which is rated at 5000-lbs.
the maximum amount of weight you can safely tow will be the lesser of the following:
- the GCWR minus the actual weight of the MH as it is loaded for travel (food, fuel, water, LP, clothing, supplies, pets, people and misc. stuff); OR
- the weight rating of the MH hitch (Class II 3500-lbs, Class III 5000-lbs, Class IV 10,000-lbs); OR
- the weight rating of your towbar - Gale_HawkinsExplorerI would keep it out of OD for sure and run a gear lower than normal down hill and up. Knew a guy with the same MH engine that towed a full size Dodge 4x4 and claimed it handled it well but that was a one time conversation. Besides the transmission weak link that is over the hitch limits I expect too.
- Dr_ChennyExplorerIt is a ford.
- Gale_HawkinsExplorerIs it a Ford or Chevy?
Either way the transmission will be your weak link I expect. - BluegrassBillExplorerI wouldn't think so. 4000lbs is about all you could tow and with rig as big as yours and that would be slow going uphill and more importantly downhill. Good luck.
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 20, 2026
