Here are some 'natural remedies' you can try using
Baking soda: To get rid of bad odor coming from your refrigerator, you can use baking soda. Take a box of baking soda and spread it on a baking sheet and then place the baking sheet in the refrigerator. For the odor to get out completely you need to keep the door of the refrigerator closed for several hours. At the same time you can also keep an open box of baking soda in your refrigerator all times.
Vinegar: White vinegar can neutralize many of the bad smells that come out from your refrigerator. Put an open cup or bowl filled with white vinegar in the fridge. You can also mix white vinegar with water and use this solution to clean your refrigerator.
Oats: You can use oats to remove bad odor coming from your refrigerator. Put oats in a bowl and then keep the bowl in your refrigerator for several hours. The bowl of oats will suck in the bad smells.
Coffee grounds: Take dry, fresh coffee grounds and spread it across baking sheets and then put it inside your refrigerator. Within a few days the smells coming from your refrigerator will go away.
Charcoal: You can also use activated charcoal to remove bad odors. Place activated charcoal in few bowls and put them on different parts inside the refrigerator. Set the temperature of the refrigerator to minimum and keep the door of the refrigerator closed for three days.
Vanilla: You can also clean the refrigerator with vanilla extract in order to get rid of the bad odor. Your refrigerator will smell fresh one you clean it with vanilla extract. Take fresh cotton balls and soak them in vanilla extract and then place the cotton balls inside the refrigerator.
Orange: Once the source of the odor is located, you can use some oranges to eliminate the lingering odor. Slice the oranges and then put them in the refrigerator. Oranges will eliminate the odor of almost anything.
