zackyboy3rs's avatar
zackyboy3rs
Equalizer Brand Hitch - Weight Bars Position Question
Do the weight bars need to be parallel to the trailer frame? I was thinking they are suppose to be parallel. The installer has mine pie sliced shaped but pulled well except for a little popping.
  • ExxWhy wrote:
    1 washer on the head = 1 hole in the bracket, according to the tech support guy I talked to at Equalizer. I would try to get it relatively parallel.
    There does come a point when more washers will add more equalizing, but make it harder to close the coupler when hooking up. I am there at 6 washers, or I would have gone to 7 and dropped the bars one.
  • 1 washer on the head = 1 hole in the bracket, according to the tech support guy I talked to at Equalizer. I would try to get it relatively parallel.
  • ah64id wrote:
    I am one hole above parallel and it works fine.
    Mine was set 2-3 holes out of parallel.
  • Ditto ah64id. We've been out of parallel for 6 years now and it seems to work fine. Probably not ideal, but it's the best setup we can manage. Trailer has handled well.
  • When I had mine I was having trouble with my TT jerking. So I called EQ to ask some questions about setup. The tech guy said I could be slightly out of parallel with bars and it wouldn't matter. Naturally you want the bars to be as close to parallel with the L brackets as that's where part of the friction is at. Obviously you don't want the bars just riding on the front or rear edge of the L bracket.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    I've got the same hitch. IMO, they should be level, or parallel as you say. The bars should ride flat on the L-piece on the frame. That's part of the friction control. You can download the manual from Equilizer and double check everything. Very easy to set up correctly and very easy to do wrong.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 16, 2026
