valhalla360's avatar
valhalla360
Navigator
Jun 11, 2018
Ford 6.2L - Thoughts
Thinking about upgrading the truck. Looking for something in the 7-10yr old range.
With the Ford, that crosses from the V10 to the newer 6.2L V8.
I guess I hadn't been paying attention. Wow, 385HP and 400ft-lb...that would make the biggest diesels from the late 90's look anemic. That jumps up form the current truck that has something like 305HP and I haven't wanted for more power.
So any concerns I should be aware of? If the cost difference is minor, would you bump up to a slightly newer truck to get the 6.2L?
Setting aside the political/environmental hot potato, for non-towing use, I'm liking that it's E85 compatible, since I started watching and E85 is around 30% lower price, so even if I lose 10-15% on the MPG, I still come out ahead on the miles per dollar (calculated a 27% increase in miles per dollar at current local prices assuming a 10% loss in MPG). I can always switch back to the standard E10 stuff if I'm going to do some heavy mountain towing or I know I want the extra range between fill ups.
Weight ratings aren't an issue, so I don't "need" diesel. Whichever one I find in better shape at better price I will go with.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
