C-172-AV8R's avatar
C-172-AV8R
Found R.V. air roof vent
Have roof air vent cover found on side of road south of Duncan.B.C. Found on the side of highway heading north If you read this let me know if you are missing one or if you see or hear of someone missing their's let them know I have it.....Mike
  • This thread is all about what being a Good Sam member used to be about. :)
  • Thanks, Mike. I certainly would appreciate it if someone helped me get my part back.
  • It's not like my newer Max cover this one has a large circle screen vent on the trailing edge that angles towards the front to keep out the rain.I cant understand how all the bolts let loose at the same time unless they had some work done on it and they forgot to replace the hardware. I agree they are not very expensive but they might not be able to find this type if it is older...Thought I would try....Mike
  • If it is just a standard cover they are not very expensive & the owner will not likely be back for it.......probably be too far down the road before it is discovered missing...... If mine were lost I would just pick one up at the next RV dealer I come across........... Good Luck.......
  • Roundtwo-40 wrote:
    Did it survive the flight?
    It did well. No damage. No hardware either....
