- mobeewanExplorerLooks like the valve is not lined up straight with the fitting. What ever is screwed into the tank fitting could be cross threaded and now starting to leak. Another though is you could have caught the valve on something or road debris hit the valve and started ripping the connection loose.
If the threads are damaged I'd clean them up as best I could to get rid of any thread imperfections and use about 3 wraps of Teflon tape to make the connection again. If it still leaked I clean up the male and female threads with a toothbrush and some alcohol and reseal using clear silicone on the threads. This is one of the rare times that I would ever use silicone. - ScottGNomadLooks like the threads are leaking to me as well.
I would remove it and clean the threads out. Then I would use some pipe dope to seal it back up rather than teflon tape because the latter may require too much torque to install. - nmhuntrExplorer
Old-Biscuit wrote:
The 'white' tank connection is 'Spun Welded' into tank. High speed tool spins the fitting melting the tank material and inserts it while plastic is hot. When material cools fitting is welded into tank
The 'black' fitting is screwed into threaded section of the 'white' connection
POLY Plastic weld repair kits available
Thanks
Looks like the threaded part is what is leaking. Headed out for a few days and when I get back I will tear into it. - Old-BiscuitExplorer IIIThe 'white' tank connection is 'Spun Welded' into tank. High speed tool spins the fitting melting the tank material and inserts it while plastic is hot. When material cools fitting is welded into tank
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 14, 2026
