Bob_Vaughn's avatar
Bob_Vaughn
Glad I was not camping
Last night it was 46 at my house and I had the heat pump running in my camper. I checked the temperature this morning and it was 64 degrees inside . Even tho I had the thermostat set at 72 degrees. The compressor just does not run long enough to maintain the set temp and yes it is a ducted Atwood 15000.......I am tired of paying authorized repair centers to fix it and no one has yet to get it to run right.....
  • Bob, I’m certainly not an expert on heat pumps, as while we have them.....we’ve never used them. My limited knowledge consists of a solenoid, downstream of the compressor, which directs ( changes direction of refrigerant flow) the hot discharge to the condenser for cooling ( ac use), or to the inside of the camper. I do know, if the solenoid fails in the ac mode, the outside finned area will get hot ( hot gas is passing through coils to cool)....if failed in the heat pump mode, the outside coils will get cold!
    Many compressors ( not sure about) have a low level/volume shutdown to protect the compressor. If your system has said shut-down, perhaps you are low on refrigerant. Most/many/all camper ac units are not designed for a refill of refrigerant! If that is the case, I’ve heard (can’t verify), that some “techs” can install a fill (schrader type) valve in the system for a refill.
    I hope that I’m not too far off on my understanding of the ac/heat pump system. Maybe someone can chime in and correct my errors.
  • JimR 1 wrote:
    On a heat pump if the temperature gets lower than 40 degrees or so they will not work and are unable to keep up. My heat pump will shut off after if the temp gets low (outside) or if there is not heat increase at the thermostat after a certain time.
    JimR
    As I said it wes 46.....the first vent had a temp of 93 then the compressor immediately shut off. The compressor did not run long enough to raise the temp in the camper....
  • Community Alumni's avatar
    Community Alumni
    JimR
  • BB_TX wrote:
    I would question if the thermostat is accurate. Or very possibly, the thermostat is in a position that heated air flows across the thermostat, warming it before the rest of the air is adequately heated. Possibly redirecting the air flow or moving the thermostat might help.
    the compressor does not run long enough to affect the thermostat..
    Something is turning off the compressor...
  • DrewE's avatar
    DrewE
    Explorer III
    Maybe it's too cool for the heat pump to be able to run continuously without the outside unit freezing up? There's a limit to how much heat it can extract from relatively cold air.
  • memtb wrote:
    Bob, you may not want to make a fall camping trip with us. 46 F would be an unseasonably warm daytime high. Plus.....you have difficulty finding a “Current Bush” to plug into! ;)
    On a more serious note, are you saying that the compressor is “cycling”, rather than staying engaged?
    If you run the forced air furnace....does the inside temperature match that of the thermostat setting?
    Yes on propane heat the thermostat works fine...the heater is located under the bathroom and over heats the bathroom and bedroom and makes enough noise to wake the dead...
  • I would question if the thermostat is accurate. Or very possibly, the thermostat is in a position that heated air flows across the thermostat, warming it before the rest of the air is adequately heated. Possibly redirecting the air flow or moving the thermostat might help.
  • Bob, you may not want to make a fall camping trip with us. 46 F would be an unseasonably warm daytime high. Plus.....you have difficulty finding a “Current Bush” to plug into! ;)
  • ppine's avatar
    ppine
    Explorer III
    Sixty four is a great temperature for inside a trailer. A lot warmer than my house in the morning.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
