jim1521
Nov 21, 2017Explorer
Your WDS is not doing anything.
The steer axle on the empty truck was 3,740 lbs. When you connected the trailer up, you lost nearly 400 lbs off of the front, and gained over 1,500 lbs on the rear axle. The WDS should balance that out. You are WAY too tongue heavy.
You need to measure the height of the wheel wells on both axles while the truck is empty, then measure them again with the WDS properly installed. They should not change - the WDS is supposed to offload some of that 1,500 lbs up to the steer axle, so that the two (steer axle and drive axle) are closer together. With all that weight on the back, it is causing the butt of the truck to drop down, and the nose of the truck to rise up - decreasing your steering ability.
I'd take it to someone who knows how to install/adjust that WDS. You're way off right now.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
