Grit_dog
Nov 24, 2017Trailblazer
jim1521 wrote:
Baja, the 1200 should do it if you stay the same (<1200 lbs TW), but if it were me, I'd go to the 1400.
Also, you MUST get the proper height shank. If you don't, it'll screw up your tires as they won't be carrying an even load.
Only if the trailer has torsion axles. With torsion spring axles, trailers need to be close to level. With tandem leaf springs, they modulate the weight between the 2 axles, until you get to extreme angles where the center link between the front and rear springs bottoms out.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
