JBarca
Dec 07, 2017Nomad II
Great pic! I see you have the 6 1/2 ft bed like mine does.
You have good truck capacity to start with. The 9,700# GVWR will be the weak area to watch but you can still be under that with a level of extra. When the WD hitch is set up right, your axle loads will be in line with your ratings when you add your; passengers, 600# of cargo in the bed and if or when you're loaded tongue weight reaches towards 1,400# when extra gear in the camper just shows up. In time, it will. You have a good foundation to create a stable towing setup. It just will take a little work until you dial it in and be glad you did with a pleasant tow.
Thanks
John
Thanks
John
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
