JBarca
Dec 28, 2017Nomad II
Baja Man wrote:
Thanks John--
I started another post on my NEW hitch set up. Thought I would get more responses seeing as this thread was already several weeks old and most people tend to view/respond to threads that are near the top of the list. Thank you for sticking with this thread!!
NOTE: I have been using my electric tongue jack to raise/lower the trailer and swing bars onto L brackets. I a y have to add 1-2 additional wood blocks under jack foot to raise it high enough to install bars on L brackets....as it's close to toping out now
OK, you have the right jacking concept. I carry a 6" wood block to put under the electric jack foot to gain enough height. On 1,700# WD bars there is no safe way to pull them up without jacking the camper and truck coupled up sky high. Then I can put the bars on by hand. Let the jack down and all the weight loads up.
I'll go look for your other post
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
