bmdakk's avatar
bmdakk
new to WD hitch with some questions
Hello, I recently purchased a 22' Sun Valley Apache TT. TV is a 92 Chevy silverado SWB. when I hook it up the TV sags LOW. So I went and purchased an EAZLIFT Round bar WD Hitch(used). Im having some trouble hooking it up correctly or what I assume is correctly. I will include pics to show what I am having a dilemma on.
First Due to the welded angle brackets for the propane tanks, I cannot position the chains vertical, they are angled towards the back. Is this OK?
Second should the Bars be parallel with trailer frame?mine Hooked up as seen in pics seem to be angled up. The rear of the TV is an inch lower than unhooked and a 1/2 inch higher at the front bumper.
I am heading out on a trip this coming Friday. just want to make sure I have it hooked up right and safe. Thanks in advance
  • bmdakk wrote:
    https://www.flickr.com/photos/151886203@N08/37372326256/in/dateposted-public/
    https://www.flickr.com/photos/151886203@N08/37419525751/in/dateposted-public/
    https://www.flickr.com/photos/151886203@N08/37419524211/in/dateposted-public/
    https://www.flickr.com/photos/151886203@N08/37419523581/in/dateposted-public/
    https://www.flickr.com/photos/151886203@N08/37419522211/in/dateposted-public/
  • I had obstructions. The extra long set screws hit the welded cross brace. I shortened the set screws so the lift bracket could be placed right up against the cross brace. The propane bottle bracket was screwed to the A frame, so I moved it up against the power tongue jack. The chains are not vertical, but almost.
    The bars should be parallel to the frame. Adjust the tension by tilting the hitch head by adding or removing washers.
    It's up to seven washers now. With 780 lb. tongue weight, it is now returning 89% of the lifted weight to the steer axle.
  • pics are finally uploaded. I cant modify the brackets without cutting off the propane tank braces
  • https://www.flickr.com/photos/151886203@N08/37372326256/in/dateposted-public/
  • "when I hook it up the TV sags LOW."
    WD hitch and bars isn't going to solve this issue. Your 25/26 year old truck is the problem. No 1500 truck should sag LOW when the tongue of a 22 foot TT is attached.
  • Modify the brackets as needed to get the chains vertical. The bars should be level when finished, adjust hitch angle or height as necessary. Ignor the rear TV height and adjust bar tension to bring the front back by 1/2 to all of the change. If the rear sags too much, that would be corrected with the springs or other added suspension support.
  • You can probably find a set of instructions for your particular hitch on line, maybe on E-Trailer, or You Tube.
    Bill
Looking for advice before your next adventure? Look no further.25,127 PostsLatest Activity: Apr 23, 2025
